After a power failure in the whole house, my MBLD went silent - no sound, no start, no led. I have checked the AC Power adaptor but it seams to work ok, I have checked and there is 12V.
Can anyone help me with this issue?
Tomek
Tomek
Have you tried resetting the unit using the reset button on the back of the unit? Also check the ethernet connection.
I have removed power supply for about 30 minutes, after that, the device has started up normally. I do not know the reason of such behavior, it works ok now, but this all is much frustrating for future.
Thanks,
Tomek
