MiniDLNA installation problem
Hey,
Sorry for my language. I have problem with my NAS server (wd my cloud).
One week ago i totally brick it… I use tutorial from this forum and i repair it using disc image.
But i have still problems. Now, after repair i can’t install transmission package, because i have error something about compatibility with structure X64…
I used this tutorial:
http://community.wd.com/t5/My-Cloud/GUIDE-Cross-Compiling-Transmission-2-82/m-p/632579#M2381
And now i have transmission.
But i noticed that my wd my cloud doesn’t share .srt files… I have only movie with substitles so it annoys me.
I find solution on internet. MiniDLNA. I started installation but i have problems from begining…
I’am using this tutorial:
http://community.wd.com/t5/My-Cloud/GUIDE-Install-MiniDLNA-on-WD-My-Cloud-firmware-series-3/td-p/755364
when i type:
echo deb http://ftp.us.debian.org/debian/ sid main >> /etc/apt/sources.list
I have there now two lines:
deb http://ftp.us.debian.org/debian/ wheezy main
is it correct?
Then i’m using apt-get update
After few seconds i have:
W: There is no public key available for the following key IDs:
7638D0442B90D010
7638D0442B90D010
W: Ignoring Provides line with DepCompareOp for package libjpeg62
W: Ignoring Provides line with DepCompareOp for package php-psr-http-message-implementation
W: Ignoring Provides line with DepCompareOp for package php-psr-log-implementation
W: Ignoring Provides line with DepCompareOp for package php-math-biginteger
W: Ignoring Provides line with DepCompareOp for package pypy-cffi
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package pypy-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python-cffi-backend-api-min
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-max
W: Ignoring Provides line with DepCompareOp for package python3-cffi-backend-api-min
Then i use apt-get install minidlna
wd-peczis:/# apt-get install minidlna
Reading package lists... Done
Building dependency tree
Reading state information... Done
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
 minidlna : Depends: libavformat-ffmpeg56 (>= 7:2.4) but it is not going to be installed
            Depends: libavutil-ffmpeg54 (>= 7:2.4) but it is not going to be installed
            Depends: libflac8 (>= 1.3.0) but 1.2.1-6+b1 is to be installed
            Depends: libid3tag0 (>= 0.15.1b) but it is not going to be installed
            Depends: libjpeg62-turbo (>= 1.3.1) but it is not going to be installed
            Depends: libvorbis0a (>= 1.1.2) but it is not going to be installed
 transmission : Depends: transmission-common (>= 2.84-2) but it is not going to be installed
                Depends: transmission-gtk (>= 2.84-2) but it is not going to be installed or
                         transmission-qt (>= 2.84-2) but it is not going to be installed or
                         transmission-cli (>= 2.84-2) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I have errors. I wan’t use apt-get -f install because at last trying it bricked my wd my cloud…
Please help me how can i install minidlna…
EDITED:
I have version: v03.03.01-156
OK solved :slight_smile:
I’ve update my wd my cloud into: v04.01.04-422
and .srt files are visible :slight_smile:
Now i don’t need minidlna :wink:
Good to know this solved your issue hopefully this can help other users.
