i have a 160gb passport. couple days ago my picture folder is suddenly gone. by calculation 50gb of my family picture folder is not showing. i tried to use data recovery software but done not show any of my pictures. i have checked my folder option for view hidden files too…but no luck. Can any body help… it is very important memory picture for my family… Help… [text deleted for privacy]
THE FIRST THING YOU NEED TO DO IS IDENTIFY HOW YOU BACKED UP YOUR FILES IF YOU USED A SOFTWARE YOU WILL NEED TO RETRIEVE THOSE FILES USING THE SOFTWARE MOST OF THE TIME SOFTWARE RENAMES AND RE ARRANGES EVERYTHING FOR ITS USE MAKE SURE YOU RETRIEVE THE FILES AND VIEW TO CHECK IF THEY ARE THERE IF IT WAS DONE USING A SYNC SOFTWARE YOU MIGHT HAVE LOST THE DATA BECAUSE SYNC SOFTWARE DONT ACTUALLY BACKUP
