The list of compatible usb wireless network adapters list the Linksys WUSB100 but show that the item MUST NOT HAVE A REVISION.
However, I tried a Linksys WUSB100 v2 and it works great!
Just wanted to pass this along since I had to return a Belkin and Netgear adapter to Walmart before finding this Linksys that worked.
I love this unit!
I really was lucky!
I had already talked to tech supporty and returned 2 other adapters to Walmart before deciding to try this one.
The box DOES NOT show a revision number on it, but when you open the box and look at the adapter it shows v2.
That’s why I thought I would let everyone know that the Linksys WUSB100 might be a good one to try firts ans save the headaches I had!
Bought my WUSB100 v2 yesterday and it worked just fine with my WDLive!
Thanks machineo!
You’re welcome! Glad I could help!
Maybe they will get the unit compatible with more adapters in the future and it will not be such a problem.
