There IS a shutdown script on the v2.x single bay My Cloud. It is: /usr/local/modules/script/shutdown.sh
See the following posts from the thread in my prior post that indicates it DOES appear to work to some extent.
Another method using SSH:
There is also discussion of unhiding the code in the CSS file that hides the shutdown option from the v2.x single bay My Cloud Dashboard in that Safe Shutdown thread.
There have been calls since the v2.x single bay My Cloud was released to bring the shutdown option back. It is IN the CSS coding but for some reason WD decided to hide it. There is even a Cloud Ideas post from over a year ago asking WD to bring it back…
As I need to change up my response as their BOT defender won’t allow three of the same exact messages,
another who has found this distressing business of no shutdown facility, and here is W.D.'s latest response, I know it’s a bit late but has anyone got this sort of response or are willing to escalate this? I doubt this will ever be rectified but one may hope
Cheers
James
Thank you for your reply and for your remarks.
Your remarks have been escalated to our higher level of support and our engineering team and we will have it under consideration for our future products.
I am truly sorry to hear that you are left dissatisfied with your product and that it does not fit your needs. I will be
more than happy to request a discount coupon for your next purchase from the WD Store, as we value you as our customer and your opinion does count. Please, do let me know if you wish to receive the 20% discount code for the WD Store.
If you have any further questions, please reply to this email and we will be happy to assist you further.
Sincerely,
Alex
Western Digital Service and Support
WD Quick View will NOT install on macOS Sierra however there is a workaround:
Right click on the installer and click on Show Package Contents.
Go to Resources folder.
You will find the installer WD Quick View Installer.mpkg
Ignore the installer security msg and allow install via System Preferences, Security
Shutdown option will now be available from dropdown menu
this post with the code edits were so helpful today after updating to Os5, thank you very much man!!!
and hopefully the devs can read this and use it for a useful firmware upgrade for us
like googling things at work right? we all were there
