Had to disconnect my old MyCloud to move it. When I reconnected it the front LED stayed a solid white/yellow. The green light on the ethernet port is flickering.
I know leaving it to think can work but its been like this for two days so I need advice on what to do next.
When you moved it did you change anything else on the local network? Like change the router or broadband providers? Have you tried replacing the Ethernet cable? Have you tried a 40 second reset? Can you access the Dashboard using a web browser or any Shares using Windows File Explorer/Mac Finer? If SSH was previously enabled can you access the My Cloud using SSH?
