lew66
August 16, 2015, 7:19am
#21
Hi Guys,
I ran the commands, ( the re-add, the remove and the add) but I get this message:
mdadm: /dev/sdc2 is not a block device.
here’s an output if it helps…
cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md1 : active raid5 sda2[0] sdd2[3] sdb2[1]
8778211776 blocks super 1.0 level 5, 64k chunk, algorithm 2 [4/3] [UU_U]
bitmap: 2/2 pages [64KB], 131072KB chunk
md0 : active raid1 sdd1[2] sdb1[1] sda1[0]
2097088 blocks [4/3] [UUU_]
bitmap: 16/16 pages [512KB], 8KB chunk
unused devices:
thanks for your help…
OK… it’s a new morning, and I tried the commands again…
this time I get the following message:
mdadm: cannot find /dev/sdc2: No such file or directory
This message appears no matter which of the three recommended commands I try.
thanks in advance for anyone’s help.
skiwi
August 17, 2015, 9:32pm
#22
Interesting.
If you type “mdadm --detail /dev/md1” it will not show the sdc2 device?
What about if you type “mdadm --examine /dev/sdc2”?
Can you post the output?
Now that your backups are finished, You can try a few more things. Can you physically remove drive 3 and re-insert it and re-try the commands?
lew66
August 17, 2015, 10:10pm
#23
Hi Mate,
I shut down the system and removed the disk, then turned it back on without the disk.
Then I shut it down again and inserted the disk and turned it back on again.
Same thing… no change. I even tried remove faulty, remove failed remove detatched… no difference… sigh…
outputs below… TIA.
root@xxxxxx root # mdadm --detail /dev/md1
/dev/md1:
Version : 01.00.03
Creation Time : Sun Nov 3 04:19:38 2013
Raid Level : raid5
Array Size : 8778211776 (8371.56 GiB 8988.89 GB)
Device Size : 5852141184
Raid Devices : 4
Total Devices : 3
Preferred Minor : 1
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Tue Aug 18 08:07:18 2015
State : active, degraded
Active Devices : 3
Working Devices : 3
Failed Devices : 0
Spare Devices : 0
Layout : left-symmetric
Chunk Size : 64K
UUID : 9d063278:a3167319:2146d3d9:3260d27a
Events : 292643
Number Major Minor RaidDevice State
0 8 2 0 active sync /dev/sda2
1 8 18 1 active sync /dev/sdb2
2 0 0 2 removed
3 8 50 3 active sync /dev/sdd2
root@xxxxxxx root # mdadm --examine /dev/sdc2
mdadm: cannot open /dev/sdc2: No such file or directory
skiwi
August 17, 2015, 10:56pm
#24
OK, remove the disk and try to mount it on your Mac.
lew66
August 17, 2015, 11:13pm
#25
Yeah… I thought of that, but I will have to get hold of an external case or cradle…
Will see what I can come up with…
If I can mount it, should I format it or something?
thanks…
lew66
August 18, 2015, 8:53am
#26
Well Hallelulia!
I shut down the EX4 and removed the drive…
I attached the drive to a USB cradle to my mac.
My mac said it couldn’t read the drive and proceded to take me into the disk utility where I bounced around for awhile before deciding to create a new partition on it… which I did… single partition using the whole 3TB.
Inserted it back into the EX4 (which has auto rebuild turned on by the way…) and powered it back up.
After it’s usual start up, the red LED came on and it said volume degraded… just like before.
ssh into the box and tried a few things and it looked just like it did before. I couldn’t remove the drive from the array as it said it didn’t exist… sigh!
One last attempt before I put my foot through the **bleep** thing… mdadm --add /dev/md1 /dev/sdc2
It returned the message mdadm: added /dev/sdc2
I was so shocked I froze up…
Finally I did a cat /proc/mdstat and sure enough it was rebuilding… telling me it needed 42,000 + minutes but it was rebuilding.
The LCD on the front of the EX4 also said rebuilding volume and showed 9999 minutes…
WHO CARES, IT’S REBUILDING!!! HOORAY!!!
I’ll post back when it’s done, but @skiwi YOU ARE A LEGEND… Kudos kudos kudos… thank you so much for your patience and all your help.
Hopefully I can give back to the community too…
Thanks again from down under!
skiwi
August 19, 2015, 3:46am
#27
That’s great news. The rebuild shouldn’t take anywhere near that time. What is it saying now?
lew66
August 19, 2015, 4:16am
#28
All done now mate.
Checked I could access all my data (which I can) and turned on the media service to let it rebuild the database.
That didn’t take too long and all is good.
Question… do I need to do anything to md0? See below… it looks like md0 is a RAID1 array and it still has sdc1 missing.
The dashboard reports all RAID volumes are active and healthy. Should I just ignore it?
root@xxxxxxxx root # cat /proc/mdstat
md1 : active raid5 sdc2[4] sda2[0] sdd2[3] sdb2[1]
8778211776 blocks super 1.0 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
bitmap: 0/2 pages [0KB], 131072KB chunk
bitmap: 12/16 pages [384KB], 8KB chunk
skiwi
August 19, 2015, 6:23am
#29
No, md0 is the system. The md1 is the RAID 5. Looks like you are good to go. the GUI should say all is good. To be sure, check the SMART status of each drive (from the GUI).
lew66
August 19, 2015, 8:40am
#30
Smart Status all good.
Thanks again for your help.
