I’ve been using the Live Hub, with one TB hard drive, for about four years and have a question. Lets say one day the unit, for whatever reason, no longer powered on. When taken apart would it be possible to easily remove the one TB hard drive?
This would be done to transfer the files to either a replacement Hub or a laptop. Thanks.
If you search this forum you will find several posts regarding this. (6 topics down)
Here’s a youtube video as well … found using gOOgle
Does that hard drive have a usb port (so it could be connected to a laptop)?
it’s a standard SATA HDD …
http://content.hwigroup.net/images/products_xl/129038/western-digital-scorpio-blue-1tb-95mm.jpg
BUY a SATA to USB Adaptor … then No Problems connecting to PC/Laptop
