G-Drive Project 8tb problems
G-Drive Project 8tb problems](G-Drive Project 8tb problems - PRO-BLADE - SanDisk Forums)
SanDisk ProfessionalPRO-BLADE
Mar 12
1 / 2
Mar 12
Mar 18
maxiorek123
Mar 12
Hello ,
Can anyone tell me why the disk turns off and restarts itself after a while when, for example, I click on the disk icon?
I have the disk connected directly to the Mac Book Pro M1 using the original cable from the set
Is it supposed to be that energy saving is turned on or is it in some mode or, I don’t know?
And my second question is whether it is recommended to connect the disk (back part of the disk) icon with the computer to the Mac Book or can a cable be connected to the second input?
thank you and sorry if these are stupid questions
Hi @divyagup247
Have you opened a Support Case? If not opened, for more information, please contact the SD Technical Support team for best assistance and troubleshooting:
