I am looking to buy a WD TV (Live or not) and found this comparison on the homepage:
http://www.wdc.com/en/products/homeentertainment/mediaplayers/
It would seem that the WD TV is a better player?
I don’t have access to Miracast but customizing the home screen sounds convenient. Are these the only 2 differences? Which player is newest and most likely to have the longest support?
Basically - which one should I get?
gderf
July 24, 2014, 2:49pm
2
You missed that Netflix is not supported on WD TV, but is present on the WD TV Live.
The WD TV player is newer than the WD TV Live.
I certainly did miss that!
Well then, no point to even look at the WD TV as Netflix is a must.
Found this interesting information in smallnetbuilder wdtv review :
“The WD TV and the WD TV Live have the same FCC ID number so they share the same hardware. Only the firmware is different.”
gderf
July 28, 2014, 4:36pm
5
Even if the hardware is identical, something tells me the firmwares are not interchangeble between the devices. That would be a too easy upgrade
Maybe a good project for the mod squad - patch the WD TV firmware so it can be uploaded to a WD TV Live SMP.
