Difference between WD Elements Play and WD TV Live Hub
I am willing to purchase a multimedia drive that allow me to watch HD movies, listen to music and watch recorded HD movies taken by digital CAM recorder. However, there are plenty of products in the home entertainment section and i don’t know which one to choose. For instance, choosing between WD Elements Play and WD TV Live hub is a challenge since their specs are almost the same.
My setup requirement as below:
  1. One big LED 52" HDTV in the hall. (I assume that i can hook the product directly to this TV using HDMI)
  2. Two LED 32" HDTV, each in a separate bedroom. (Which interface to use to stream content from the product to these TVs? … Assuming that the TVs do not have a built-in WiFi or Ethernet interface) and i don’t want to buy separate WD product for each TV.
Any help would be appreciated.
The WD TV hub is better if you have a DLNA TV, since you can stream the movies or videos to different TVs at the same time.
