Can`t connect 2025 iPad Air M3 to My Passport Wireless Pro
I’m trying to establish a wired connection between the two.
My iPad is not recognising the MPWP.
However it does work with my iPhone 15 Pro.
I’ve tried reformatting the drive as Ex-Fat and APFS and Mac OS Extended with no joy.
I’m using an adapter USB-A to USB-C to connect using the supplied cable and
I’ve tried using a MoGood USB-C to Micro-B cable with no luck.
I’ve tried restarting all devices.
I keep getting the same result…it connects to the iPhone but NOT the iPad.
I’ve run out of troubleshooting ideas.
Does anyone have any suggestions?
