Great - looking forward to it
Is it possible to install Midnight Commander on MyCloud EX2 Ultra?
Hello everybody
I am new to this topic and tried to read more than 1300 comments so far …
I have a WD Mycloud Gen 1 and want to install DSM on it. In the past i experiment with Linux with my raspberry pi.
I tried to install DSM, but there is no how to guid or something like that. In the how to install stands i should look in the file > connect via telnet. But there is no such file?! Please help me. i just need a seamless installation guide.
Thank you all
telnet is a tool that used to be present on all windows installations - that changed with 7 or 8, not sure.
You can either add it via add/remove programs| windows components or use an alternative tool like putty which also provides telnet functionality.
Then follow the steps in “Connect to WDMC via Telnet and run this commands:” …
Good luck:
Use PuTTY instead. Its better.
Hey Guys!
I was struggeling the last few day to get a clean Debian installation up and running on my WDMC EX2 Ultra 2 Bay NAS.
I tried to stick as close as possible to the information found here
The files I’ve used
- uImage: WDMyCloud-Ex2-Ultra/Debian/uImage-4.8.6_ex2u.bin
- Initrd: WDMyCloud-Mirror-Gen2/Debian/Dev/uRamdisk
- root fs: WDMyCloud-Ex2-Ultra/Debian/MCMgen2-jessie-basic-armhf.tar.xz
What I’ve done so far
1. attached the hdd to my Linux machine and created the raid
parted --script /dev/sda "mklabel gpt \
mklabel gpt \
mkpart primary 0% 512MB \
mkpart primary 512MB 4096MB \
mkpart primary 4096MB 100% \
set 1 raid on \
set 2 raid on \
set 3 raid on"
mdadm --create /dev/md0 --level=1 --metadata=0.9 --raid-devices=2 /dev/sda1 missing
mdadm --create /dev/md1 --level=1 --metadata=0.9 --raid-devices=2 /dev/sda2 missing
mdadm --create /dev/md2 --level=1 --metadata=0.9 --raid-devices=2 /dev/sda3 missing
2. installed the rootfs
mount /dev/md1 /mnt/root
wget ...WDMyCloud-Ex2-Ultra/Debian/MCMgen2-jessie-basic-armhf.tar.xz -O - | tar xvJf -
3. connected via UART and booted from USB
usb reset; fatload usb 0:1 1200000 uImage-4.8.6_ex2u.bin; fatload usb 0:1 2000000 uRamdisk;
bootm 0x1200000 0x2000000
Result
the NAS stops booting with the message: # /dev/md1 not exist!
you can find my full bootlog here.
Has anyone successfully installed Debian on the WDMC EX2 Ultra yet?
Can you give ma a hint what i missed out or did wrong?
Thanks in advance
Marcel
I think kernel dont have “md” module (Dont support software raid).
Try to use only one HDD w/o raid (/dev/sda[1,2,3])
Note: Ramdisk can boot to busybox with all needed for reformat (prepare) HDD (parted, mdadm, wget, etc…)
Hello mr. Fox!
Thank you very much for the fast reply!
works from busybox. so i thought the kernel supportts it? or dos booting from an array require additional kernel featuers?
i want set up a raid1 mirror.
Do i need to recompile my own kernel and recreate a ram disk?
Has someone done this previously?
Is it possible to install the os to the nand?
Thanks, thats how i do it now, didn’t realize it earlier…
update
found this guide here: https://themm.net/public/ex2u/start
going to try that tomorow…
Yeah, sorry, my fault. Kernel is same, so md-module exist and work.
There another problem: Sometime (idk why) md0 transfer to md127 (md1 → md126, md2 → md125, etc…)
Reboot and check (mdadm -As && cat /proc/mdstat)
/ # mdadm -As && cat /proc/mdstat
mdadm: No arrays found in config file
this method worked like a charm, install OMV faild due to systemd requirements…
later i tried to use docker with self compiled Kernel but it did not boot…
Read “REQUIREMENTS” section. Need recompile kernel with these options for support Systemd.
Also you can build 3.10.70+ kernel from official Marvell GIT repository (Use Config and dts file from Mirror Gen2 + replace 0x2000000 (512MB) to 0x4000000 (1GB) in “Ram” section of dts)
thanks for your help, but i wasted enough time on this ■■■■ now…giving it up now.
i am using a self build orangPi NAS (armbian) as private server, this is working perfectly stable for months with a total HW cost of around 30€ (wo. HDDs)!
i revert the original firmware and try to sell off this rubbish on ebay
Any word on if the DL2100 is supported ? @Fox_exe Thanks!
There are some interesting repositories on github according DL2100 support:
Still busy with work? Or any new release on the horizon?
Thx
Sorry for the double post -
@Fox_exe
Was there any really stable release that would be ready for “productive” use or should I rather fall back to WD?
Need some kind of solution in place asap
Hi !
Please can you explain clearly how to proced step by step.
I thing It will interrese a lot af beginner as me…
For exemple, you write : “Easy to install: Just upload my “special” firmware.”…Thank for that but where to find exactely your special firmware…?
Can you give the direct link…
The best : Write a tuto
Regards
Jean
@Fox_exe Hi thank you for your great work. WDMC 2gen’s usb is still not working?
Fixed. Download and unpack to /boot
Hello @Fox_exe . Thanks a lot for your firmware.
I was using your firmware for clean Debian jessie on MyCloud Gen2. Then I upgraded it to stretch and kept the old sshd config file. However, after reboot ssh didn’t recognize the same password. So I tried to inspect the issue by booting from your USB image, which worked before the upgrade. However MyCloud couldn’t boot from USB anymore. Now I have a clean Debian stretch but completely lost it access.
Do you have any idea why the USB boot is lost and how I can rescue it please?
