If I use 300x450 size instead of 300x200 it will impact speed or it only generate bigger (at higher resolution and MB size) thumb without lose performance ?
I’ve been using 300x450 (under 70kb) for months now … and the speed is fine for me.
If you’ve been using 200x300 … then that’s fine (poster aspect ratio is still correct for this theme)
So, if you’re happy with the picture quality of your Thumbnails, then there’s no need to redo them.
(for the larger thumbnail views however, they might not be as ‘clear’ as a larger resolution)
I made a simple template on thumbgen designer to generate a spare sheet (cover 400x350) as you suggest, but I get files between 100-150 KB I think they don´t impact on performance but is pretty cool to get that smaller size at that resolution.
I downloaded and tried the last build you uploaded yestarday night, the theme looks very cool now (even in beta), the fronted menu is great but what I don´t like a little is the unfocus effect on the non-selected items, in my opinion they look better as before without begin unfocus…
I know it Joey and I know you have to spend a lot of time tweaking and doing the thing works, so I really really appreciated what you do. I just wanted to inform you what I though about that, sorry If I make you feel bad about it.
By the way I will be waiting the Dark version! for the moment I have to reconstruct my Gallery thumbnails to adjust your theme.
how to i get the backdrop to show with the thumbnail like the screenshot above? is there a thumbgen template i can use?
Absolutely nothing to do with ‘Thumbgen’ or “Templates”
If you use the WDTV Live Hubs Internal Scraper it automatically creates Backdrops which are then available when you press the “Option” button on your Remote Control and select “View Backdrop Photos”
Remember this a NON-Moviesheet Theme … everything can be done on the Hub.
Optionally. if you are not happy with the Thumbnail picture quality then you can use a 3rd Party Program to Generate Higher Quality Thumbnails.
Joey can you explain me how the linksheet method works, I been reading but I don´t fully understand how is set, e.g. I don´t know where to store all the sheets or how to set all my movie files…
hoping someone can help i would like to change the @@director to the mpaa rating ex: pg13 etc. what would be the variable to add in the xml for gallery view?
