Bit busy at the moment, but look at page 31 6th post down.
Using the Linksheet method, which is all documented here, I have made my own linksheet portrait views and just overlay them on the large icon, as the original theme.
Has said in previous post, the bulk off my video files are not movies, so only do the overlays for movies ( about 160 ) Although the SMP is limited to 30 Meg, still the size of my theme is only 7Mb with all 160 Linksheets for movies.
I made my Linksheets using Photo Elements, but can be done by any method you choose.
Thanks to JoeySmyth for his help in doing this - And his motto at the end of his mails
Where can I look to see how to run themes from a thumbdrive and where can I look to see the actual procedure to use moviesheets. I have been following this a little but until now I thought SMP users were not really suited to using moviesheets. Now that I see that we can use thumbdrives and moviesheets, I want to learn more.
At the moment we haven’t a specialized version (linksheet) of the ALASKA theme,
so we would change the XMLs manually like you posted in the wdlxtv board ?
Yes, it’s easy to Modify my Theme for use with Linksheets … But using Linksheets in Gallery View with Movies XML suffers slowdown. So the simple workaround is to delete the Movie xmls.
However, i don’t want to do this. I would still like to use the Youtube Trailer feature and Info Views.
So ive been tinkering around with ways to still keep them and still use Linksheets. (In the process ive swapped a number of views around and mixed Linksheets with Standard thumbnail views. Below a test screenshots with the view description. The Linksheet is just basic info for the time being… there is still room for MPAA and Media Flags.
This is “Gallery View” No Linksheets Used / Hub Movie Metadata / Standard Thumbnails [rv_gallery_browse_page.xml]
This is “Video Browse” Linksheets Used / Standard Thumbnails [rv_video_browse_page.xml]
This is “List View” No Linksheets Used / Standard Thumbnails [rv_list_browse_page.xml]
This is “Large Video View” Linksheets Used [rv_large_video_browse_page.xml]
This is “Preview View / aka Lowlist” Linksheets Used / Standard Thumbnails [rv_preview_browse_page.xml]
This is “Info View” Standard Thumbnails / Hub Movie Metadata [metadata_view_info.xml]
Re-designed Main Menu with Animated Scrolling Icons
Working on this … and also Non Moviesheet Version + Night Version … No idea when i’ll be done.
Can you help me out and tell how I can get mine setup like this? Been messing with it but can’t figure it out. I don’t even see this option when going through my views???
Yes, thanks for your test-screenshots of the work in process , Joey.
It is like having the possibility to look over the artist’s shoulder … amazing .
About “linksheets” , in the test screenshot of ALASKA’s "List Viewy " there is no using of linksheets.
Is it (generally) not possible using any linkssheets in rv_list_browse_page.xml ?
Can we use “linksheet” background-images in this xml/music_browse.xml ?
With “” linksheet" background-images " I mean large, dark fanart images.
These wallpapers could be used in several themes … quite flexible … as a “linksheet” background without processing lots of (?) manual design steps in a graphic programme.
First I want to say I love this theme and this was the main reason to update to 3.05.10 and I’m very happy, In fact the non-moviesheet feature is excellente I never use it so for me is a Win.
By the way Joey are you working on a “dark version” right ? If that so, how is the progress!?
