Hi there!
The power adapter of my WDBWLG0050HBK elements drive, which says 0.5A input, broke and I am wondering if an old adapter from the old version of the elements series,
which says 0.6A input, will work properly, without causing any potential problems…
This is the old one
Is there a chance that the drive will draw more power than it can handle (0.5A) by connecting the adapter with 0.6A input?
Or does it draw only the power that requires and is designed for, and therefore it’s fine to use it?
Any help would be greatly appreciated!
Thanks in advance!
