Won't auto mount encrypted volume
Running firmware 2.11.169
Several firmware updates ago my mycloud ex4 stopped auto mounting my encrypted volume. I’ve tried disabling auto mount and then enabling it again. There’s just no way to get it to work. What’s the deal? Was support for this option dropped without dropping the dialog? Is there any way for me to figure this out if I ssh into the device?
Hi nunya_business,
The link below will allow you to call support.
