I’ve an old usb Wireless Adapter Netgear WPN111, it’s work fine on my computer. So i’ve decided to test on my WD Tv Luve Hub (with the latest Firmware), but it doesn’t work (on the both Usb port), i’ve no erros messages on the screen.
It has to be comparable with the hub firmware. The firmware only supports a limited number of WiFi chipsets and will not work with all adaptors. There is a WD list which details adapters that are supposed to work with the hub but note that it must have the same version / revision number. Other adaptors with a comparable chipset will also work but its a case if trial and error.
