Where to find replacement power cord?
I have the wdbaaf0015hbk-01. I’ve moved several times and can’t locate the power adapter. Is there a place I can check to see what adapters are compatible for my unit? I believe my portable external hd is 5 years old, or more. I think it is a 500 gb my book essential but I haven’t turned it on in a few years, so I can’t be sure.
The product number is showing it’s a 1.5 T. Would any 12v dc power adapter work then?
from googling the model number you provided it’s a WD My Book Essential 1.5TB
You will need a 12 Volt / 1.5 Amp / 18 Watt power supply.
WD Power Supplies: Power Adapters for Western Digital Products
