WD82PURZ-85TEUY0 (SN: CDK8YG6K) 8Tb - Loud clikcing sounds on write / read
Recently I have purchased 2x WD Purple series hard drives 4Tb and 8Tb.
When connected to the PC, the 4Tb drive is working allright and does not stand out in any kind of way.
The 8Tb drive also works, but there are twice as loud clicking sounds coming from the drive than from the 4tb drive.
When sent back to the wholesaler for testing (ELKO Group, Latvia) we received a notification that the drive is fine and received a printout from various WD testing tools with 100% “PASSED / OK” results in all tests.
If the tests are fine, but clicking sound is much higher - is that a warranty case, can I be sure about the data safety, can the drive be replaced?
Wholesaler refuses to exchange the drive since all testing results are “green”
Thank you in advance for your answer.
Regards,
Didzis.
You could refer to the following link: Error
This topic was automatically closed 60 days after the last reply. New replies are no longer allowed.
