WD RED makes a squeak noise on power off
Hello, this is my second post. The first one is being ignored by Akismet because it contains links to videos of the sound.
It has been more than 10 days, please check my other post or at least un-spam it so I can receive advice about my question.
Kind regards,
You post was approved my a moderator on Jun 10 and was responded to on Jun 12.
We recommend you take a look at this link about drive noise.
https://support.wdc.com/knowledgebase/answer.aspx?ID=568
