I am about to buy IBM server system ( IBM System x3100 M4) to build NAS, but still wondering if WD red drive is compatible with IBM System.
Any comment / recommendation ?
Thank you in advance,
Chai
Chai
It’s hard to tell compatibility of drives to a computer system, usually this type of compatibility info will come from the system manufacturer, which in this case is IBM. Typically as long as the computer can support the drive capacity that you want to use and it falls within the drives compatibility it should work. For WD Red this would include a light workload and no more than 5 drives in the array. I included a link to the other specs for the drive below:
Thank you very much for your support
I would probably wait til someone that has running WD RED on IBM system to share their experiences. ![]()
