Hi everyone,
My book WD external hard drive has not been showing up on my computer and all it is doing is flashing the whole time. I have tried a few things and it has not worked.
Can someone please let me know if something can be done?
Thanks.
Hi everyone,
Thanks.
i have the same problem with my elements 3.0 (which i bought just yesterday), im using acer 4755g/win8 64bit, the usb2.0 is ok with wd, but usb3.0 cannot detect wd elements. how to fix this? i use the usb3.0 port for flash drive, printer, etc, i just don’t know if it trully works as usb3.0.
thanks.
If it is showing in USB 2 but not USB 3 you probably need to check your USB updates. If your USB 3 is a addon card try the manufacturer’s site or the computer buildr’s site.
Joe
