WD Elements is not mounting and when it does it disconnects after a while
my WD is not mounting or shows in finder. and when it does it shows only every now and then, yet i cant use it. while copying files it suddenly stops and shows that i disconnected it wrong. when it does show i can see the backup from time machine and files stored.
USB ports are working perfect
i’m working on a macbook, OSX 10.7.5
my WD elements is not having an extra power suppy, can’t give more details as i cant get connected to it.
guess it is the 500GB version
it is possible the unit to enter in stand-by/sleep mode after a certain period of inactivity. The WD My Book and WD Passport drive families allow you to change the sleep-timer behavior and even disable it, but this feature is not available for the WD Elements family.
I’d recommend checking if you are able to obtain a hard drive sleep timer control app from the App store and see if it helps.
i just changed the settings into 4 hours,
it connected directly to my macbook
and is copying now.
getting an error code -43
and the macbook is no longer able to find the drive
Support by Country
