yes it is raid 1
You can try mstsc with Admin again. It says the disk ar not initialized which takes time, but I am concerned you log file is not as long as mine is
did you compare the 2 thumbs?
yes it is raid 1
Ok, yea i did try to log in with Administrator and Admin as password but still it says its wrong
Is there no way i could maybe go in to root files of the recovery to see what is the password. If it does not except my password or the Admin password what is it then? There must be a way to find itđ€
either setup is not completing therefore there is no logins available or somehow your keyboard is not sending Admin
You can take the left hand drive out and slave it to a pc and look at the files recovery laid down. I am not in my office right now and it is not turned on but I think the password is in a cfg file in a panther directory under windows
You could also use something like 7-zip to compare the checksums of the .swm files between the mounted iso and the created thumb drive to make sure it is laying the files down properly.
If you have any AV other than Microsoft uninstall it.
hi, i took out the left drive and connected it to my pc.
the only file i found that contain any password in the panther directory is âunattendâ and its a XML File:
Im trying to send it on this chat but it doesnt come out right
This is the recovery txt file from the PANAM recovery flash:
[03/13/2017 14:48:39 628] Starting ServerRecovery.
[03/13/2017 14:48:39 628] AddFirewallException
[03/13/2017 14:48:40 628] Listener CListener created
[03/13/2017 14:48:40 628] Listener UDP listener created
[03/13/2017 14:48:40 628] Listener TCP listener created
[03/13/2017 14:48:40 628] ServerRecovery started and is listening for request.
[03/13/2017 14:59:48 5c4] Listener TCPListener::TcpEventCallbackStatic
[03/13/2017 14:59:48 5c4] Listener TcpEventCallback
[03/13/2017 14:59:48 5c4] Listener TCPListener::TcpConditionCallback
[03/13/2017 14:59:48 5c4] Listener TcpConditionCallback from 192.168.1.2
[03/13/2017 14:59:48 5c4] NumberUnauthenticatedSessions is called.
[03/13/2017 14:59:48 5c4] StartSession
[03/13/2017 14:59:48 5c4] Received connection.
[03/13/2017 14:59:49 708] Entering HandshakeThread
[03/13/2017 14:59:49 708] Exiting HandshakeThread
[03/13/2017 14:59:50 5c4] Processing query backup machines request.
[03/13/2017 14:59:50 5c4] End processing query backup machines request.
[03/13/2017 14:59:54 5c4] Processing query backup machines request.
[03/13/2017 14:59:54 5c4] End processing query backup machines request.
[03/13/2017 14:59:55 5c4] Processing query backup machines request.
[03/13/2017 14:59:55 5c4] End processing query backup machines request.
[03/13/2017 14:59:56 5c4] Processing query backup machines request.
[03/13/2017 14:59:56 5c4] End processing query backup machines request.
[03/13/2017 14:59:56 5c4] RestoreProtocol::Disconnect is called.
[03/13/2017 14:59:56 5c4] RestoreProtocol::Disconnect - calling socket shutdown.
[03/13/2017 14:59:56 5c4] MC_Closed
[03/13/2017 14:59:56 5c4] Calling ~CSession.
[03/13/2017 14:59:56 5c4] SessionComplete: Number of active connections: 0.
[03/13/2017 14:59:56 5c4] StartSession - close socket
[03/13/2017 14:59:56 5c4] End StartSession
[03/13/2017 15:00:16 5c4] Listener TCPListener::TcpEventCallbackStatic
[03/13/2017 15:00:16 5c4] Listener TcpEventCallback
[03/13/2017 15:00:16 5c4] Listener TCPListener::TcpConditionCallback
[03/13/2017 15:00:16 5c4] Listener TcpConditionCallback from 192.168.1.2
[03/13/2017 15:00:16 5c4] NumberUnauthenticatedSessions is called.
[03/13/2017 15:00:16 5c4] StartSession
[03/13/2017 15:00:16 5c4] Received connection.
[03/13/2017 15:00:16 720] Entering HandshakeThread
[03/13/2017 15:00:16 720] Exiting HandshakeThread
[03/13/2017 15:00:16 5c4] Processing query system disk request.
[03/13/2017 15:00:16 5c4] GetSystemFirmwareType returned 2
[03/13/2017 15:00:16 5c4] pVdsDisk->GetPack failed with hr = 0x80042417
[03/13/2017 15:00:16 5c4] Ignore. One case is uninitialized disk.
[03/13/2017 15:00:16 5c4] GetPhysicalDriveNumber (\?\PhysicalDrive0)
[03/13/2017 15:00:16 5c4] End processing query system disk request.
[03/13/2017 15:00:16 5c4] Processing disk validation for reset request.
[03/13/2017 15:00:17 5c4] CoCreateInstance CLSID_DOMDocument60 succeeded.
[03/13/2017 15:00:17 5c4] GetValue - Unable to find element [ImageFile].
[03/13/2017 15:00:17 5c4] pVdsDisk->GetPack failed with hr = 0x80042417
[03/13/2017 15:00:17 5c4] Ignore. One case is uninitialized disk.
[03/13/2017 15:00:17 5c4] QueryPartitions - QueryPartitions failed with hr = 0x80042417
[03/13/2017 15:00:17 5c4] ValidateDisk - DiskValidationResults = 1
[03/13/2017 15:00:17 5c4] End processing disk validation for reset request.
[03/13/2017 15:00:17 5c4] Processing factory reset request.
[03/13/2017 15:00:17 5c4] End processing factory reset request.
[03/13/2017 15:00:17 734] Entering BeginResetThread
[03/13/2017 15:00:17 734] Executing Reset
[03/13/2017 15:00:17 734] DiskImaging::Reset, bCleanDisk = 1
[03/13/2017 15:00:17 734] pVdsDisk->GetPack failed with hr = 0x80042417
[03/13/2017 15:00:17 734] Ignore. One case is uninitialized disk.
[03/13/2017 15:00:17 734] Executing CreatePartition (0x6400000, 0x100000, style=2)
[03/13/2017 15:00:17 734] Calling CreatePartitionEx (0x6400000, 0x100000, style=2)
[03/13/2017 15:00:20 734] Executing CreatePartition (0x8000000, 0x6500000, style=2)
[03/13/2017 15:00:20 734] Calling CreatePartitionEx (0x8000000, 0x6500000, style=2)
[03/13/2017 15:00:20 734] Executing CreatePartition (0xf00000000, 0xe500000, style=2)
[03/13/2017 15:00:20 734] Calling CreatePartitionEx (0xf00000000, 0xe500000, style=2)
[03/13/2017 15:00:24 734] Executing CreatePartition (0xffffffffffffffff, 0xffffffffffffffff, style=2)
[03/13/2017 15:00:24 734] Calling CreatePartitionEx (0x1c2b28fbe00, 0xf0e500000, style=2)
[03/13/2017 15:00:30 734] Found extent with VDS_DISK_EXTENT_TYPE = 4 that is not a volume.
[03/13/2017 15:00:30 734] Found extent with VDS_DISK_EXTENT_TYPE = 5 that is not a volume.
[03/13/2017 15:00:30 734] WimApply (C:\sys.wim, 1, a:, 2, *)
[03/13/2017 15:00:30 734] Calling WIMCreateFile
[03/13/2017 15:00:30 734] Calling WIMRegisterMessageCallback
[03/13/2017 15:00:30 734] Calling WIMGetAttributes
[03/13/2017 15:00:30 734] Calling WIMSetTemporaryPath
[03/13/2017 15:00:30 734] Calling WIMLoadImage
[03/13/2017 15:00:30 734] BuildReferenceList - Extension found is [.wim]. Skip building file references
[03/13/2017 15:00:30 734] Calling WIMApplyImage
[03/13/2017 15:00:31 734] Progress 0
[03/13/2017 15:00:31 460] Progress 0
[03/13/2017 15:00:31 460] Progress 1
[03/13/2017 15:00:31 460] Progress 2
[03/13/2017 15:00:31 460] Progress 3
[03/13/2017 15:00:31 460] Progress 4
[03/13/2017 15:00:31 460] Progress 5
[03/13/2017 15:00:31 460] Progress 6
[03/13/2017 15:00:31 460] Progress 7
[03/13/2017 15:00:31 460] Progress 8
[03/13/2017 15:00:31 460] Progress 9
[03/13/2017 15:00:31 460] Progress 10
[03/13/2017 15:00:31 460] Progress 13
[03/13/2017 15:00:31 460] Progress 14
[03/13/2017 15:00:31 460] Progress 16
[03/13/2017 15:00:31 460] Progress 18
[03/13/2017 15:00:31 460] Progress 19
[03/13/2017 15:00:31 460] Progress 20
[03/13/2017 15:00:31 460] Progress 22
[03/13/2017 15:00:31 460] Progress 24
[03/13/2017 15:00:31 460] Progress 25
[03/13/2017 15:00:31 734] Progress 25
[03/13/2017 15:00:31 734] Cleanup
[03/13/2017 15:00:31 734] WimApply (C:\os.swm, 1, E:, 2, )
[03/13/2017 15:00:31 734] Calling WIMCreateFile
[03/13/2017 15:00:31 734] Calling WIMRegisterMessageCallback
[03/13/2017 15:00:31 734] Calling WIMGetAttributes
[03/13/2017 15:00:31 734] Calling WIMSetTemporaryPath
[03/13/2017 15:00:31 734] Calling WIMLoadImage
[03/13/2017 15:00:33 734] Search pattern for reference file: [C:\os.swm]
[03/13/2017 15:00:33 734] File [C:\OS.SWM] is skipped.
[03/13/2017 15:00:33 734] File [C:\OS2.SWM] added to ref list
[03/13/2017 15:00:33 734] File [C:\OS3.SWM] added to ref list
[03/13/2017 15:00:33 734] Calling WimSetReferenceFile [C:\OS2.SWM]
[03/13/2017 15:00:33 734] Calling WimSetReferenceFile [C:\OS3.SWM]
[03/13/2017 15:00:34 734] Calling WIMApplyImage
[03/13/2017 15:01:18 734] Progress 50
[03/13/2017 15:01:18 444] Progress 50
[03/13/2017 15:01:25 444] Progress 50
[03/13/2017 15:01:32 444] Progress 50
[03/13/2017 15:01:39 444] Progress 51
[03/13/2017 15:01:48 444] Progress 51
[03/13/2017 15:01:54 444] Progress 51
[03/13/2017 15:02:03 444] Progress 51
[03/13/2017 15:02:09 444] Progress 52
[03/13/2017 15:02:14 53c] Progress 52
[03/13/2017 15:02:16 444] Progress 52
[03/13/2017 15:02:21 53c] Progress 52
[03/13/2017 15:02:26 444] Progress 53
[03/13/2017 15:02:29 444] Progress 53
[03/13/2017 15:02:32 53c] Progress 53
[03/13/2017 15:02:36 444] Progress 53
[03/13/2017 15:02:42 444] Progress 54
[03/13/2017 15:02:47 444] Progress 54
[03/13/2017 15:02:53 444] Progress 54
[03/13/2017 15:02:59 444] Progress 54
[03/13/2017 15:03:04 444] Progress 55
[03/13/2017 15:03:10 53c] Progress 55
[03/13/2017 15:03:15 53c] Progress 55
[03/13/2017 15:03:18 53c] Progress 55
[03/13/2017 15:03:22 444] Progress 56
[03/13/2017 15:03:26 444] Progress 56
[03/13/2017 15:03:29 444] Progress 56
[03/13/2017 15:03:32 444] Progress 56
[03/13/2017 15:03:35 53c] Progress 57
[03/13/2017 15:03:39 53c] Progress 57
[03/13/2017 15:03:43 444] Progress 57
[03/13/2017 15:03:49 53c] Progress 57
[03/13/2017 15:03:57 444] Progress 58
[03/13/2017 15:04:03 444] Progress 58
[03/13/2017 15:04:12 444] Progress 58
[03/13/2017 15:04:18 444] Progress 58
[03/13/2017 15:04:29 444] Progress 59
[03/13/2017 15:04:35 444] Progress 59
[03/13/2017 15:04:41 444] Progress 59
[03/13/2017 15:04:50 444] Progress 59
[03/13/2017 15:04:59 444] Progress 60
[03/13/2017 15:05:09 444] Progress 60
[03/13/2017 15:05:25 444] Progress 60
[03/13/2017 15:05:36 53c] Progress 60
[03/13/2017 15:05:49 444] Progress 61
[03/13/2017 15:06:02 53c] Progress 61
[03/13/2017 15:06:09 444] Progress 61
[03/13/2017 15:06:13 444] Progress 61
[03/13/2017 15:06:16 444] Progress 62
[03/13/2017 15:06:19 53c] Progress 62
[03/13/2017 15:06:24 444] Progress 62
[03/13/2017 15:06:30 53c] Progress 62
[03/13/2017 15:06:34 444] Progress 63
[03/13/2017 15:06:37 444] Progress 63
[03/13/2017 15:06:48 444] Progress 63
[03/13/2017 15:06:51 53c] Progress 63
[03/13/2017 15:06:54 53c] Progress 64
[03/13/2017 15:06:57 444] Progress 64
[03/13/2017 15:07:02 444] Progress 64
[03/13/2017 15:07:19 53c] Progress 64
[03/13/2017 15:07:32 444] Progress 65
[03/13/2017 15:07:47 444] Progress 65
[03/13/2017 15:07:54 444] Progress 65
[03/13/2017 15:08:06 444] Progress 65
[03/13/2017 15:08:09 444] Progress 66
[03/13/2017 15:08:14 444] Progress 66
[03/13/2017 15:08:17 444] Progress 66
[03/13/2017 15:08:20 53c] Progress 66
[03/13/2017 15:08:23 53c] Progress 67
[03/13/2017 15:08:28 444] Progress 67
[03/13/2017 15:08:35 53c] Progress 67
[03/13/2017 15:08:45 444] Progress 67
[03/13/2017 15:08:54 444] Progress 68
[03/13/2017 15:09:01 444] Progress 68
[03/13/2017 15:09:09 444] Progress 68
[03/13/2017 15:09:15 444] Progress 68
[03/13/2017 15:09:20 444] Progress 69
[03/13/2017 15:09:26 444] Progress 69
[03/13/2017 15:09:31 444] Progress 69
[03/13/2017 15:09:37 444] Progress 69
[03/13/2017 15:09:43 444] Progress 70
[03/13/2017 15:09:50 444] Progress 70
[03/13/2017 15:09:56 444] Progress 70
[03/13/2017 15:10:01 444] Progress 70
[03/13/2017 15:10:07 444] Progress 71
[03/13/2017 15:10:13 444] Progress 71
[03/13/2017 15:10:18 444] Progress 71
[03/13/2017 15:10:25 53c] Progress 71
[03/13/2017 15:10:49 444] Progress 72
[03/13/2017 15:11:19 444] Progress 72
[03/13/2017 15:11:25 444] Progress 72
[03/13/2017 15:11:31 444] Progress 72
[03/13/2017 15:11:36 444] Progress 73
[03/13/2017 15:11:42 444] Progress 73
[03/13/2017 15:11:48 444] Progress 73
[03/13/2017 15:11:55 444] Progress 73
[03/13/2017 15:12:01 444] Progress 74
[03/13/2017 15:12:07 444] Progress 74
[03/13/2017 15:12:13 444] Progress 74
[03/13/2017 15:12:20 444] Progress 74
[03/13/2017 15:12:49 734] Progress 75
[03/13/2017 15:12:49 734] Cleanup
[03/13/2017 15:12:50 734] Execution [BCDEdit.exe /store a:\EFI\Microsoft\Boot\Bcd /set {bootmgr} device partition=a:]
[03/13/2017 15:12:50 734] Execution [BCDEdit.exe /store a:\EFI\Microsoft\Boot\Bcd /set {memdiag} device partition=a:]
[03/13/2017 15:12:50 734] Execution [BCDEdit.exe /store a:\EFI\Microsoft\Boot\Bcd /set {default} device partition=E:]
[03/13/2017 15:12:50 734] Execution [BCDEdit.exe /store a:\EFI\Microsoft\Boot\Bcd /set {default} osdevice partition=E:]
[03/13/2017 15:12:50 734] Execution [BCDEdit.exe /store a:\EFI\Microsoft\Boot\Bcd /set {FWbootmgr} displayorder {bootmgr} /addfirst]
[03/13/2017 15:12:50 734] Reset completed with hr = 0x0
[03/13/2017 15:12:50 734] Exiting BeginResetThread
[03/13/2017 15:12:57 5c4] Processing reboot request.
[03/13/2017 15:12:57 5c4] Stop listening for any requests.
[03/13/2017 15:12:57 5c4] End processing reboot request.
[03/13/2017 15:12:57 5c4] Calling ~CSession.
[03/13/2017 15:12:57 5c4] SessionComplete: Number of active connections: 0.
[03/13/2017 15:12:57 5c4] StartSession - close socket
[03/13/2017 15:12:57 5c4] End StartSession
[03/13/2017 15:12:57 628] Stopping listener
[03/13/2017 15:12:57 628] Listener CListener destroyed
[03/13/2017 15:12:57 628] Listener UDP listener destroyed
[03/13/2017 15:12:57 628] Listener TCPListener destroyed
[03/13/2017 15:12:57 628] Program exit with hr = 0x0
[03/13/2017 15:12:57 628] START ~CSessionMgr
[03/13/2017 15:12:57 628] END ~CSessionMgr
I managed in a way to get Windows Server 2008 running but was kinda tricky and i dont think its right.
What i did was, i looked at on how the WindowsServer2012 was constructed (The modified version that has TightVNC integrated) and i basically just changed a few files and copied the Windows Server 2008 setup files to the directory where 2012 was.
I inserted the thumb that contained the modified version of Windows Server 2008 and i managed to log in and went through the setup process. Once completed, i then just logged in with the Username as âAdministratorâ and password as âP@ssw0rdâ (Which was the default login details of the modified 2012 Windows) those details i found in a XML file called âunattendâ
the problem is with that is, i was only able to use CMD on the desktop, nothing else. i tried running several commands like , control panel ect but it wouldnt allow me. I managed to open taskmgr with that and i was able to install a program via CMD but thats it, nothing else.
one of the main error i used to get after the PANAM recovery and after everything was successfully installed, recovered etc is âLogon Failure; user account restriction. Possible reasons are blank passwords not allowed, logon hour restrictions, or a policy restriction has been enforcedâ
thats on the main login page after mstsc as Administrator
Yes Admin is the password in the unattend file and your Panam log file looks fine.
You got a voltmeter to test the battery?
Could you see the date with the hacked 2008 install?
For some reason the unattend setup is not happening and it is not making Admin the password.
I could use my tongue lol nope i dont have a voltmeter. do you think it can be the battery?
nope, couldnt see the date. i just had a CMD
Well you say have checked the checksum for the iso
you have tried different thumb drives
you leave the pc on until the wizard completes.
The log file looks good
My thoughts are that setup might not run if the bios is set to 1989
Ok, but the cmos battery can cause the wrong date if its flat right? Is there not a way i can access the bios of the server?
No way to get to bios without video that I know of
Ok
I dont know what to do now
Cant i change the password now that the drive is connected to my pc?
Or if i can find a way to edit the recovery files, WIM, SWN etc⊠i know about Deployment and Imaging Tools that i can might tweek the Recovery files but thats a bit too complex
Hi Gramps, well i decided to install Windows Server 2012 R2 an it works. The only prob i have with that is the LCD and the fan speed. Do you have an idea on how to program the lcd? I tried this method but its kinda complicated:
WD DX4000: Building Windows Server 2012, part 3 â the LCD | BLUGGED
That dude is a lot smarter than me. That looks like the ticket though
Hahaha but its like Chinese to me, i hve no idea how he does those steps
