WD Blue WD10EZEX made noise while spinning
As topic, After turned on my PC , My hard disk spun and made really loud noise. Suddenly it made a kind of electric sparks and stopped the disk. Then same thing happened over and over again until my PC is completely booted. So when I checked at the computer drive, It could not find My Hard disk(Drive D)
Sorry if it’s too complicate to read. Please tell me what information I have to add more for better analysis, Thanks.
As a recommendation, test the drive using a different set of cables.
Also check if the drive is showing on the bios of the computer or disk management.
Thanks. I’ll try
