Thumbgen problem
Hi!
Completly new at Thumbgen I downloaded latest version and selected “WDTV Live Movie Sheet” from the included templates
Thumbgen works fine and the correct info is shown and generated
but all my WDTV Live Gen 3 is showing are the thumbnails, no movie info is shown
I´m probably missing something simple, so I hope one of you can help a n00b out :slight_smile:
thnx in advance /Dibblah
Options > Input/Output Naming > Movieinfo export > .xml > Export using WDTV Live Hub format
eg.
ahhh! thanks and have a great day! :smiley:
