Replacement disk for MBL Duo (Mirror mode) needed
Mentor support today told me that an identical disc model is no more available, so I should buy a similar one on free market and plug it in.
Up to now I thought I cannot just plug in a disk, but this disk has to get a special preparation and/or formatting before it can be used in a MBL Duo.
Which of both is right? Can I simply buy a “similar” WD green having same capacity, and plug it into my MBL Duo, without any preparation? If I proceed in this way: will MBL Duo synchronize both disks without loss of data?
Thanks for helpful feedback
Willy from germany
Hi
Wilfried_Bauer,
It is recommended to use the same model drive with same capacity and specifications.
For More information, You can reach to us from the link given below.
The link below will allow you to call support.
