Remote shutdown with SSH - please help
Hi
I would like to shutdown my WD Sharespace remotely using SSH
When I logon with putty I can use command “poweroff” and this works like a dream
I would like to create a batch command for that.
I tried to use plink.exe but without success.
plink.exe -ssh -pw welc0me root@192.168.1.200 poweroff
Could anyone help?
Marcin
Hi there, try to contact the user TonyPh12345, he’s your best bet!
After playing a little I made it finally work.
plink.exe -ssh -l root -pw welc0me 192.168.1.200 /sbin/poweroff
I hope it can help someone
and remember it is zero in password, not O
Thanks to this command my APC CS 350 can work with WD Sharespace with help of and old laptop with XP on board (I use it as a print server anyway).
WD Sharespace is powered through APC.
When power goes down Laptop uses it’s own battery. When battery level goes below xx% script is started to shutdown WD Sharespace.
I have my APC connected via USB to PC but it seems to be completely obsolete.
Marcin
