I have a number of public shares on my DL4100, I access them with Windows 10. For some the recycle bin works, for other with identical share settings it does not. Does anybody have a clue?
Thanks.
Thanks.
This is unusual. The described behavior can be expected using certain permissions since users will not see deleted files if they do not have permission to access the source share from which the files were deleted. However, this should not apply to Public shares.
Perhaps it would be best to contact WD Support about this. You can do in the following link:
Be sure to provide as many details as possible with regards to the issue and the troubleshooting steps you have tried so far.
Thanks for the recommendation. I followed your advice.
