Problem With mY WD Element 1TB
i buy a WD Element 1TB i delete some data wrong so i want to back them there is any way to do that?
Hello Lury, Welcome to the WD Commnunity. You will need to get a data recovery software to be able to get the data back of the drive as the WD Elements does not have any software for this. Using Google you should be able to find several options.
