This is my first post on the WDC forums. I have a My Passport Essentials SE drive attached to my PC running Windows 10. I downloaded the WD Drive Utilities application and ran it with the following results:
Run Drive Status Check: SMART status passed.
Run Quick Drive Test: Quick Drive Test failed.
Run Complete Drive Test: Complete Drive Test failed.
I then ran CHKDSK on the drive. It found and corrected a couple issues. Then I ran the Windows defragmenter on it. After that was completed I once again executed the above three WD Drive Utilities, but the results were unchanged.
Can someone please help me figure out what the problem might be? Thanks in advance.
Joe
