Problem of Password...!
Dear All, My friend bought a WD My Passport External Hard Disk and he connected it to his Computer and given a password and now I have received that External Hard Disk but It can not be opened due to Password taken and My friend & I don’t know the password so what is the Solution, Need your Help about this Problem…!
Your kind co-operation will be appreciated…
Regards,
Abdullah Makhdum
Afghanistan
abdullahmakhdum92@yahoo.com
If you can’t remember the password you can only wipe the drive. There is no master reset. The data is hardware encrypted by a board inside. If you try connecting as an internal or in a different enclosure the data will be encyrpted.
Joe
