"Power Off Retract Cycle" count increased on two Easystore drives seemingly without cause
In the past week the “power off retract cycle” count for two of my Easystore drives increased for no reason I can think of. I’ve never removed my external drives without properly ejecting them first, and I have not observed any other issues with the drives in question: I’ve never heard any sounds from my computer indicating that they’ve been randomly/accidentally disconnected from the USB ports, so I’m sure that’s not the reason for the seemingly out of nowhere upticks in “power off retract cycle”. I use different USB cables for each drive, and I use different ports for each drive.
And the really weird part is that I’m 99% sure that the retract cycle count increased right after I safely removed them from my PC, because it was first thing I noticed the next time they were connected. And these were two separate incidents a week apart, not the same day. It was the exact same conditions for both drives: safely ejected without a problem, but with an increase in the retract cycle count the next time they were connected to my PC. There is absolutely nothing wrong with the drives otherwise (they’re only a couple of months old), and nothing about my environment has changed or shifted that could account for the change in S.M.A.R.T. readings.
I don’t get it, are they somehow not powering down properly even after receiving the signal to do so from the computer? Is it a bug in WD’s firmware? Has anybody experienced something like this before?
