Unable to mount my WD hard drive! Shows up in disk utility but will not open??? I have seen numerous other people post about this with NO SOLUTION???!! HELP PLEASE
Try to verify or repair the drive using disk utility.
Check this link for more information.
this worked for meā¦
Ā Ā Ā 1. Run "Activity Monitorā first and then plug in the problematic HD. Notice a program called āfsck_hfsā suddenly starts up using alot of CPU power.
Ā Ā Ā 2. Highlight this file and in the window that opens up, click on the āquit" icon.
Ā Ā Ā 3. The HD suddenly shows up on your desktop as usual and a window opens up saying that the drive is unrepairable, BUT you can copy/recover files off it and save to another drive. Breathe a HUGE sigh of relief and away you go!!!
