Network connection issue
I’ve had my wd tv live for 8ths and all was ok. I got a virgin super hub and it fails to connect, it sees the network, prompts for passwords just fails to login.
Tried
Updating firmware
Changing hub to modem, using router
None worked
Any further info required?
Any ideas?
OK, so I see that a superhub is a combo modem/wireless router.  So what is the “it” you are referring to?  Are you talking about your WD Live or your superhub?
If the it is the WD Live, you likely need to set up your Network shares again, so see the first post in this thread:
