Hi all, this sure is more complicated vs. the last time I needed more storage!
I use an old XP box (32 bit) as a home server on my LAN. I need to increase the storage capacity, and I need to use USB2 for now. However, I expcet at some point I’ll finally replace the old XP box (so I’m guessing the next would have USB3 and/or esata).
My understanding is that, for simplicity’s sake, I’m limited to 2TB, correct? (that’s ok if so)
I’ve been looking at drives like Caviar Green, Samsung’s EcoGreen, and Hitachi’s Deskstar 5k3000 – under the assumption that I don’t need to maximize performance – rather, my main concerns are stability and noise (and, related, heat). If I’m on the wrong track, pelase let me know.
But now I also have to worry about “Advanced Format” – eg, 4k rather than 512 size sectors – and I have to “do something” to ensure Caviar Green (and, I gather, Samsung’s EcoGreen) will work. However, I gather the Deskstar 5k3000 still uses 512 size sectors, and so that should “just work.”
What do I actually need to do to get the Caviar Green to work via USB to an old 32bit XP? And, fwiw, I’d like whatever that is to be “future friendly” for when I replace the XP box. Also, assuming I set it up correctly, would I still be better off with a 512 sector drive?
Thanks, much appreciate your help!
