Speeds transfers in My Passport (500 GB) USB 3.0 = from 30 to 80 MB/s
Ridiculous speed for a port that is announced with a maximum of 5 Gb/s :confounded:
Installed the latest firmware for My Passport (v1.019)
Installed the latest drivers for the motherboard chipset (Intel Z75)
OS: Windows 8 Pro
PC: HP Pavillion H9-1101es “Phoenix”
Motherboard: IPMMB-FM “Formosa” by Pegatron
Where is the problem?
Thanks!
Your PC HDD.
It’s not because USB3.0 has 5gb/s (potential) speed that in the normal world you will have it. The fastest, at least from memory, is transfering from a SATA2 HDD. The speed you have are probably the best you will ever get.
I have a HDD and a SSD. Both are connected to a SATA 2.0 connectors at a speed of 6 Gb/s.
I still say, where is the problem?
p0tatis
November 11, 2012, 2:01am
4
you need a SSD and a SSD to get to those speeds. The External HDD has only 30-80MB/s read/write speeds.
