So happy to see that this theme (and thread) is still banging around. It is still my favorite theme, and likely will be for a long while.
is there anyway to get the grid layout to work with moviesheets? i have the wdtv smp but moviesheets don’t work when i set the grid layout…
by the way love the theme, thank you
if you want moviesheets on the grid view (which is actually called “Preview Browse” view)
then you’ll have to use “Linksheets” (Moviesheets only work with “Gallery Browse” view)
but, 2 things
The theme will need to edited to support Linksheets
You’ll need to use Custom Firmware on your SMP
(because the SMP will only support 30MB of Linksheets using Official Firmware)
oh ok, i have a lot of movies and prefer not to redo my entire collection with linksheets. is there possibly a way to have more than the single row of covers when using gallery mode? i have a lot of movies and see it as a pain to only have the single row at the bottom of the screen… sorry if this question seems silly.
oh ok, i have a lot of movies and prefer not to redo my entire collection with linksheets. is there possibly a way to have more than the single row of covers when using gallery mode? i have a lot of movies and see it as a pain to only have the single row at the bottom of the screen… sorry if this question seems silly. thank you JoeySmyth
sure it’s possible … example: my “Welo Mini Mod” for Gallery View (No Moviesheets needed)
http://community.wd.com/t5/WD-TV-Themes/Welo-Gallery-MiniMod/m-p/568062#M11742
Great! thank you, now i can just apply this to kudos theme and customize it to match !! that looks great by the way!
well i should ask would it be ok if i mod this theme to match? how would i go about making kudos look similar? i just want to have my kudos theme gallery mode to look like that so my wife would enjoy my wdtv more.
Sure
“Theming” … requires xml and graphics editing
The 1st problem though is … if you have more than a single row in Gallery Browse, then that’s gonna obscure the Moviesheet
But if you don’t care about the Moviesheet, then it would be pretty easy to adapt the Welo “look” into the Kudos Theme
JoeySmyth excuse, you can kindly help me
here
http://community.wd.com/t5/WD-TV-Themes/Small-Change-Theme-for-linguaccia22/td-p/888067
if the only one I know that and able to help me
please reply
