make sure the Bundle File name is not a ZIP file, rather it should be named KUDOS V4.1.Bundle
Cheers LB
Cheers LB
Lesterbangs wrote:
Hi Bearing
I assume you are in the UK or similar…
I don’t know for sure and I hope others may chime in here, but the BBC iPlayers (i believe) is zoned to the UK region and is only available with a certain revision (and greater) of the WD SMP Firmware.
I run Firmware version 1.10.XX primarily as it allows 20 Network shares and to avoid a bug in the later firmware that does not allow Moviesheets for TV Shows.
Between myself and some mates we run about 12 WD SMP all on this firmware without issue. You may have it go up to a later firmware, but you will lose the ability for Moviesheets on TV Shows, regardless of which “Moviesheet” theme you run.
Maybe TW or JoeyS can confirm or otherwise,
Cheers LB
Hi LB,
Seems that something has happened server side at WD with regards to iPlayer, I hadn’t noticed it missing before I changed the theme. WD are currently working on the problem.
Cheers,
Rob
Lesterbangs wrote:
Hi MirkoB
Thanks for the feedback.
Actually something similar to: http://community.wdc.com/t5/WD-TV-Live-Hub-Themes/ALASKA-RESURFACE-REMIX/m-p/432720#M8530 Do you think, it would be possible to implement this functionality into your theme?
I would love to add that info and create a Sheet that looks like that . I have put the code in but the Movie Data does not appear. Ill have a play. In the meantime try this here
Cheers LB
hi LB,
i have changed the text color in the rv_gallery_browse_page.xml, the fontsize and number of rows and now it looks great for me (i can see all the informations i need)!
Thank you so much!
Regards, Mirko!
Hi I am having issues seeing the sheets for TV shows. Is there any special method for applying them? I have’nt changed any options so it’s using the .bundles defaults. I can’t seem to figure out where the problem is. Any help is appreciated thank you.
running:
Thumbgen 1.3.2.0
WDTV 1.12.14 FW
Shows are in their own folders ex.
30 Rock/
Season 7/
*.mkv
*.xml
**edit**
I downgraded my WTDV SMP to 1.10.13 and everything works great
Hi Oenahs
Your Problem is WDTV 1.12.14 FW
Please downgrade the firmware to 1.10.13. Instructions here
Its a bug with WD Firmware and it effects all Moviesheet Themes
Regards
LB
Lesterbangs wrote:
Hi Oenahs
Regards
LB
Thanks got it sorted it out. Another issue I seem to be coming across now is screen size. I have have to minimize the screen size calibration to 95% to be able to see icons and full titles. At 100% the theme is a little overscaled other than that this theme is great and I cant wait to see more releases thank you for all your work.
Hi OENAHS
The scaling issue is the OVERSCAN setting on your TV. Turn Overscan off and all will be good.
Cheers LB
Lesterbangs wrote:
Hi OENAHS
Cheers LB
Thanks for the response that did the trick
Downloaded the theme and love it but I have a couple of questions regarding layouts:-
The folder image does not always get populated. Why not, am I missing coding or something?
Also when doing TV Series, the episodes are not in sequence and some have the folder image missing. I have checked all the episodes and they have all the same setup/information. Any ideas. The image missing should be the same one used upper left.
If this is not the way to post questions (with images) please advise. My first post
Any help or advice would be appreciated.
I’d like to change my layout like signer above!
@Foxwater, try ThumbGen, Here , Here and Here are some decent tutorials on how to create this, and in the start post there are links to sheets for Kudos and also a tutorial.
Also remember that firmware 1.12.14 FW does not work with sheets.
Lesterbangs wrote:
Hi Oenahs
Regards
LB
@LesterBangs, i liked Iron Man and Ms Perry just tried your weekly build, don’t know how it works, but i had to setup my WDTV again after your installing your theme.
Can you reposition the stars and heart in your theme, or just remove them?
Only thing im missing is the watched icon in your theme.
Hi Mickroz,
Thank you for taking the time to reply! i’ve managed to roll back my firmwear to 1.10.13 and seem to be able to produce moviesheets that i like apart from the issue signer raised i.e
i have a movie reel there in the folder place, so maybe thats because of im on weekly build, so i guess that should be there.
cant help you with the folder image, havent encountered that.
In Thumgen (French) with Thumbgen bundle :
-current profile " Kudos V4.1 Movisheets DVD"
-moviesheet editor " Kudos V4.1 Moviesheets "
I have an error in French:
"format chaine entree incorrect "
Help …
Hi LB,
do you have an idea why the tv-show sheet doenst fit correctly?
1st pic: tv-show sheet theme
http://www.abload.de/img/1s7uc5.jpg
2nd pic: movie sheet theme
http://www.abload.de/img/2q1ucp.jpg
thank you
Hi Foxwater
I had this prob… i simply went to the folder where your movies are located (along with your thumbgen data) remove the “wdtv folder”… unplug your smp and back in! that should refresh everything
Let me know how you go!
Hey muso84, thanks for the tip! it worked a treat, apart from one genre folder which won’t show no matter what i do! i’ll keep messing around with it tho!
Hi Wiesel
TV Sheet Bug you have found… fixed in Bundle on first page. Re-download it or…
If you are keen, copy this file into the \Thumbgen V1.3\Templates\KUDOS V4_1 TV Show Sheets on your PC
Cheers LB
thanks a lot
I have a problem with the moviesheet and the imbd rating bar. All my moviesheets are showing a full blue imdb-bar (of 10). The rating number itself is fine. I already installed thumbgen v. 1.3.2.1 and installed the KUDOS V4.1 bundle again but without change. When I select the standard thumbgen template, the imdb bar with the stars is working correctly.
