At this time, the WD TV product line does not support the use of single USB drives larger than 2 TB. Doing so may cause corruption to the data, or damage to the partition. Our dual and network drives larger than 2 TB’s can continue to be used with the WD TV products. WD is currently working on a remedy to this situation, and will notify our customers when it becomes available.
This issue has been resolved for the WD TV Live, Live Plus, and the Live Hub in the latest firmware updates.
I am SO angry I just got a 3tb WD hard drive and spent 2 days transfering data FOR NOTHING, it never crossed my mind I had to go online and look arround in forums to find out it was all worthless. It is amazing you can not use a wd hard drive with your own products what is the point of buying your stuff? or did you guys think the 3 tb era would never come? And what is taking you guys so long to get a solution for this? Are you a garage company? how many people/genius are working on this? man you guys should not been sleeping at all until you solve this. I give you my word if you not solve this soon I will never buy anything from you and will tell everyone I know about the “great company” and “amazing” “customer care” you have.
We do understand the frustration of not being able to know this going in. And like Guy said, we are currently working on it. However, just in case you didn’t know, you can connect the drive to a computer and the WD TV Lives can access it over the network. The other thing I would caution, is that if you connected it directly to the WD TV, you may have damaged the partition. So, if nothing plays, or the drive becomes inaccessible, that’s because the partition or data was corrupted or damaged. If that happens, you will need to repartition and reformat the drive. Then, copy all the data back to it. Keep in mind that repartitioning and reformatting will destroy what data you have on the drive.
