I have a G-Drive mobile USB used as backup from MacBook Pro under HFS+. A more recent MacBook Pro under HighSierra (APFS file system) does not see it when connected to the USB-C plug.
Disk Utility does not see it either. What can I do?
Plugged through an adapter (USB-C USB). Light on G-Drive is off
Solved by unplugging plugging several times. Sorry for the disturbance.
Glad to see you got it working.
