empty folder problem
I use 2tb my cloud home , i see the folders i copied from my windows pc to mac pc as empty when i check it from my mac pc ,does anybody have information about this issue?
Hi canutku,
https://support.wdc.com/support/case.aspx?lang=en
The link below will allow you to call support.
