Custom themes installation not possible!
Device: WD TV Live Hub
Firmware: 2.08.13
The device doesn’t recognize manually installed themes within the wd.tv\theme folder and it only allows the downloading of some other themes. How to fix it?
change your content source…
press on the red button of the remote and select the internal storage.
You will then be able to install the themes.
