Compile Vim hit problem: ncurses library is not usable
I installed debian 7.8 64 bit.
Then download
Ex2 GPL: http://support.wdc.com/product/download.asp?groupid=906&sid=220&lang=en.
extrace it.
Installed many dependencies, including
apt-get install libncurses5-dev.
Download vim source to fw-1.05.36/WDMyCloud_EX2_GPL_v1.05.36_20150624/Open_Source_packages/
Run source source.me then cd vim74 package folder
I also copy one xbuild.sh to vim74 folder. Just replace configuration line as following:
./configure --host=${TARGET_HOST} --prefix=${MY_PREFIX} --disable-selinux --disable-gpm --disable-nls --disable-gtktest --disable-netbeans --disable-darwin --enable-fontset --with-tlib=ncurses
But it complained:
checking --with-tlib argument… empty: automatic terminal library selection
checking for tgetent in -ltinfo… no
checking for tgetent in -lncurses… yes
checking for tgetent in -ltermlib… no
checking for tgetent in -ltermcap… no
checking for tgetent in -lcurses… no
no terminal library found
checking for tgetent()… configure: error: NOT FOUND!
      You need to install a terminal library; for example ncurses.
      Or specify the name of the library with --with-tlib.
Could anyone help me here?
Thank you.
I have never tried this since it is not supported. Lets see if another user can share some experience regarding this topic.
I suspect that 64-bit OS is the culprit in your case. If you cannot find a 32-bit equivalent version for the Linux version you are using, then switch to an older version for which there is a 32-bit version. Many of the libraries needed to compile the firmware are 32-bit only.
Please click the star under my username to give me a kudo if this resolves your problem.
Cool!
It works now on 32bit Debian!
Thank you!
Excellent!! Please also mark my previous post as the solution…it might benefit others if they have a similar/same issue.
Oh, hit another problem:
/xbuild.sh build
configure: creating cache auto/config.cache
checking whether make sets $(MAKE)… yes
checking for gcc… arm-marvell-linux-gnueabi-gcc
checking whether the C compiler works… yes
checking for C compiler default output file name… a.out
checking for suffix of executables…
checking whether we are cross compiling… configure: error: in /root/wdmc-build/WDMyCloud\_EX2\_GPL\_v1.05.36\_20150624/Open\_Source\_packages/vim74/src': configure: error: cannot run C compiled programs. If you meant to cross compile, use –host’.
See `config.log’ for more details.
Starting make in the src directory.
WOW!
Finally it works now!!!
Will share tomorror when time is permit :slight_smile:
Glad to hear it. I suspect you figured out that you had to cross compile.
I tidied up my steps as following:
Install Debian 7.8 32bit.
Install following packages:
echo "deb http://ftp.debian.org/debian wheezy-backports main contrib non-free" >>/etc/apt/sources.list
apt-get -t wheezy-backports install qemu-user-static
apt-get install binfmt-support
apt-get install make libtool
apt-get -y install build-essential automake libncurses5-dev build-essential intltool checkinstall
apt-get build-dep nmon
apt-get build-dep vim-gnome
apt-get -d source zlib openssl curl libevent
apt-get install libssl-dev libreadline-gplv2-dev
apt-get install lib32z1 lib32ncurses5 lib32bz2-1.0
Then:
cd /root
mkdir wdmc-build && cd wdmc-build
Download Ex2 GPL: http://support.wdc.com/product/download.asp?groupid=906&sid=220&lang=en to this folder.
Once you extracted, you will get a file named: My_Cloud_EX2_Release_Notes_GPL_v1.05.36_20150624.txt
Follow that file till 3.3 as following:
1. Introduction
        This file will show you how to build the WDMyClound EX2 firmware.
        1.1 # tar zxvf WDMyCloud_EX2_GPL_v1.05.36_20150624.tar.gz
        1.2 # cd WDMyCloud_EX2_GPL_v1.05.36_20150624
        1.3 # export HOME_DIR=`pwd`
2. Install tool-chain
        2.1 # cd $HOME_DIR/toolchain
        2.2 # tar zxvf armv7-marvell-linux-gnueabi-softfp_i686_64K_Dev_20131002.tar.gz
3. How to build Open source modules? For example: build attr-2.4.46
        3.1 Install compiler toolchain
        3.2 # cd $HOME_DIR/Open_Source_packages
        3.3 # source source.me
Please note: source source.me under Open_Source_package is very important!
Compile existing ncurses lib in Open_Source_packages:
tar xf ncurses-5.7.tar.gz
cd ncurses-5.7/
./xbuild build
./xbuild install
cd /root/wdmc-build/WDMyCloud_EX2_GPL_v1.05.36_20150624/firmware/module/crfs/lib/
ln -s libncurses.so.5.7 libncurses.so.5
Download vim74 source tar ball to Open_Source_packages folder, extract it.
Put following content as xbuild.sh into vim74 folder:
#!/bin/sh
unset CFLAGS
unset LDFLAGS
unset LIBS
CFLAGS="-I${PWD}/../_xinstall/${PROJECT_NAME}/include"
CXXFLAGS="-I${PWD}/../_xinstall/${PROJECT_NAME}/include"
export CFLAGS
export LDFLAGS
export CXXFLAGS
MY_PREFIX=$PWD/../_xinstall/${PROJECT_NAME}
export vim_cv_terminfo="yes"
export vim_cv_tty_group="world"
export vim_cv_tty_mode="0620"
export vim_cv_getcwd_broken="no"
export vim_cv_memmove_handles_overlap=yes
export vim_cv_stat_ignores_slash=yes
export vim_cv_tgetent=zero
export vim_cv_toupper_broken=no
export LDFLAGS="-L/root/wdmc-build/WDMyCloud_EX2_GPL_v1.05.36_20150624/firmware/module/crfs/lib/"
xcp()
   echo "sour: $1"
   echo "dest: $2"
   cp -f $1 $2
xbuild()
   make distclean
   ./configure --build=i386-linux --host=arm-linux --prefix=${MY_PREFIX} --disable-selinux --disable-gpm --disable-nls --disable-gtktest --disable-netbeans --disable-darwin --enable-fontset --with-tlib=ncurses
   make
if ["$1" = "build"]; then
   xbuild
else
   echo "Usage : [xbuild.sh build]"
fi
then run:
./xbuild.sh build
Then you will get src/vim in ARM format!
Good Luck!
