I am interetsed in the same: how to upgrade kernel?
I have had clean debian on here with owncloud install for over a month. It is running fine, except the load average never goes below 3.00 i saw somewhere else that this could be a kernel bug so that is why i am interested in upgrading the kernel. The version I have now is what was in included in Fox’s clean debain build.
Thanks to Fox and all that made this happen! My WD my cloud works so much better with this clean debian and my cloud installed on it.
no… i try it from the v4 firmware. i saved the data, with a external usb drive. how can i recover the mycloud with 4tb. i tryed the solutions i read in the forum, but nothing works with restore image from extract firmware files, and my linux know how are bad …i net a easy tut with step by step to recover the bricked cloud and i use the lubuntu live cd and i have in the command fdsik -l the message Permission denied
i have problem… point 1 to 7 works with and now point 8-1. see this in the terminal… root@lubuntu:/home# mdadm --create /dev/md0 --level=1 --metadata=0.9 --raid-devices=2 /dev/sdb1 /dev/sdb2
mdadm: super0.90 cannot open /dev/sdb1: Device or resource busy
mdadm: /dev/sdb1 is not suitable for this array.
mdadm: super0.90 cannot open /dev/sdb2: Device or resource busy
mdadm: /dev/sdb2 is not suitable for this array.
mdadm: create aborted
После установки дебиана немогу установить openmediavault, получяю каждый раз ошибки
Google translate:
Hi everyone, help pozhalusta restore my HP.
After the installation of Debian can`t install openmediavault, poluchyayu each time an error
root@MyCloud:~# dpkg-reconfigure locale
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = “en_US.UTF-8”,
LC_ALL = “en_US.UTF-8”,
LANG = “en_US.UTF-8”
are supported and installed on your system.
perl: warning: Falling back to the standard locale (“C”).
locale: Cannot set LC_CTYPE to default locale: No such file or directory
locale: Cannot set LC_MESSAGES to default locale: No such file or directory
locale: Cannot set LC_ALL to default locale: No such file or directory
dpkg-query: package ‘locale’ is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
/usr/sbin/dpkg-reconfigure: locale is not installed
Is there a way to increase the size of the boot partition? Running out of space for Emby to install. I don’t want to risk destroying the data partition!
I have the following problem after the last update, I can not select any other option of the panel. But running ssh is normal, including other applications sickbeard or transmission.
To fix this, re-install Debian clean and then upgrade to OMV, it worked perfectly, after a few hours, try to connect again, but do not have access from the web interface, either by ssh. When checking my router I realize that does not take the IP address that is reserved, reboot a few times and the lights go white and in less than a minute remaining in solid green.
Try the TFTP recovery without success, there is a way to perform the method of recovery 1 without losing data?
If you press reset button - nothing happend. OMV not used that stuff.
I have many materials about this device. If you need something (And you speak Russian) - i try to answer. Some useful info available in my Google.Drive.
BTRFS: Yes, you can run it, but you cant get speedup or similar (Low resources - 2corex650MHz CPU and 256MB ram)
