If you press reset button - nothing happend. OMV not used that stuff.
I have many materials about this device. If you need something (And you speak Russian) - i try to answer. Some useful info available in my Google.Drive.
BTRFS: Yes, you can run it, but you cant get speedup or similar (Low resources - 2corex650MHz CPU and 256MB ram)
To fix this, re-install Debian clean and then upgrade to OMV, it worked perfectly, after a few hours, try to connect again, but do not have access from the web interface, either by ssh. When checking my router I realize that does not take the IP address that is reserved, reboot a few times and the lights go white and in less than a minute remaining in solid green.
Try the TFTP recovery without success, there is a way to perform the method of recovery 1 without losing data?
someone who can help me with this? not seem to be bricked but I have no way to enter, because not taking ip
First of all ,excuse me if there is some spelling mistake or you do not understand something, english is not my mother tongue.
I have purchased a WD My Cloud 2TB, very cheap, but I am very dissapointed. I have tried to make something with the official firmware, but it is impossible to access from outside of my local network to a protected folder (with password).
My last hope is this thread and try OMV (I have used it a little bit in a Raspberry Pi, is very easy to make it work and friendly). I see Fox_exe is making a port of DSM (they say Synology is even better but, the hardware is too expensive). Here my questions:
Once you install Clean Debian and OMV, I guess you lose all the WD Software. ¿Is there a way to come back to factory settings? I ask just in case I need to the 2 year warranty that I have.
When you install OMV it looks you do not lose data, only system files. ¿Does it happens the same with DSM? I ask because in a week I am going to be in vacation, and I am not going to make changes in my device for 20-30 days. In case you lose your data intalling DSM, maybe I should better wait and install it in september.
¿What would you recommend me to do? Sorry if it is already answered, but the thread is so long, that I could not read completly.
Yes, you can rewert to original firmware (Also you can use “Unbrick instructions” for that)
For install DSM need repart HDD. So - you loose all data on HDD. But yes - posible to save data (Need change partition number from 4 to 3 and resize and reformat other partitions. Its long way, but its possible.
DSM 5.2 stable, but have few bugs. I upload fixed and updated version soon.
I am reading the installation instructions for DSM. To repart HDD I need to disassemble the WDMC and take the HDD apart from the case. In this case I lose the warranty. Do you think would be possible to install DSM without opening it?
If not, I think I am going to use OMV by now, and later I would try DSM, when my WDMC gets older.
Does DSM have all the additional packages available as armhf? If so, it would be amazing to have stable DSM on the mycloud. Having everything in the one, nice interface, instead of multiple different packages, all with their own ports to open, would be something special. I look forward to the stable version, and might I suggest you set the boot partition with room to spare so we can install all the extras we want?
@Fox_exe, Thank you for your great job. I have installed the DSM on mycloud step by step by your instructions ,but when I connect to mycloud via webgui ,it’s said that “No Hard Disk on Mycloud”.What is the problem ? How to fix it ? Thanks.
trying to revert to original wd firmware but have an issue.
chmod: невозможно получить доступ к «install.sh»: Нет такого файла или каталога
and i am unable to find the share directory
-bash: cd: /DataVolume/shares/Public: Нет такого файла или каталога
which is where my firmware file and script is located.
please help? many thanks
FIX. search for Public Directory
find . -type d | grep Public
Succesful restore to official WD firmaware backup. once restored a factory only reset is required to restore shares and users. take 30 mins of a flashing white led. but it works!
I was able to follow the steps in the DSM 5 procedure, until the recovery part. When I run Start_Ping, the computer says “Packet.dll is missing” and I cannot go further and I cannot figure out how I can install the packet.dll.
May I know if this process can be done on Linux or Mac? Or it can only be done on Windows? My main machine is a Mac and I can easily boot into Ubuntu Live USB, but I have to borrow a Windows machine to do that everytime.
Step2: I have the dll-problem. I have installed the _software (also as admin), but the dll could not be found. My probably wrong resolution: I’ve copied the missing dll from other applications on my computer to the recovery dir. Now I can run the batches, but I think nothing happens.
When I put the DSM-box in my network, it gets an IP, but WebGui is not reachable, Telnet and ssh are refused.
Will it help to copy bootscripts manually when SATA-connected to Linux-box?
Nevertheless: Fox! Great work! I wish I could do something like that rudimentary.
