the 1 tb wont power on . i hve not used it for the past couple of months and now when i want to use it , it does not work.
checkek the adapter it works
its still under warranty
what to do? any ideas
The usual ts will be trying different cable and different computer
Verify if the drive appears on disk management
try updating the drivers
if still does not work replace the drive
