I have been running without many problems since I first got my drive. I copied over approximately 1tb of my M4V files to my shares, and approximately 35gb of music for the iTunes library.
I also have a large share dedicated to all my ebooks.
Needless to say, I have amassed a large sum of data and have backed it all up on my new drive.
I have been running the TwonkyMedia Server for approximately 1 month now, and other than not supporting my previous DVD copies on MKV containers, it works pretty flawlessly when streaming to my different devices.
As of today however, I was attempting to connect to my media server using my PS3 and realized I had left the ethernet cable unplugged. Once I plugged it back into my network, I saw within a minute my TwonkyMedia Server appear.
However, as soon as I clicked to stream from it, it decided to kick me out and I have been without my media server since then.
I have attempted the following steps:
upgrade to latest firmware
reboot as well as shut down my hard drive to regain its functionality
All this has done nothing to help my Twonky MediaServer from appearing on my network to any of my devices.
I see the Twonky configuration screen and have the ability to “Enable” and “Disable” it, but the “Status” screen continues to show nothing.
I have tried a rebuilt as well as a rescan, but without any luck.
This is incredibly frustrating, as you can imagine.
To make absolutely certain that I did not lose any data, I enabled SSH on the book by following the easy enough steps by going to http://ip_address/UI/ssh and I have successfully discovered that all my shares are indeed in tact. I can mount any of these shares without any troubles either.
By running ps aux I see that TwonkyMediaServer IS running in the processes once I start it from the GUI, but still I cannot find it on my network.
The only solution that I’ve been able to search for online has been the use of the “reset to factory default” option, which clearly states that it “erases all data” on the drive. Does this also include ALL my shared content? I don’t care about resetting the UI and getting this thing back up and running, but I don’t have the external space nor the time to start copying over 1tb on my network.
WD claims that it can connect and transfer at high speeds over a gigabit network, I’ve yet to hit over 15mb/sec of constant traffic, and just a tad over 20mb/sec when directly connected to my Macbook Pro (static assigned IPs of course).
This last set of statements makes it obvious that the rate at which I would need to copy over my content to a non-existent drive of that size could take me well over 8-9hrs, time I cannot afford to waste.
Can anyone help me regain access to TwonkyMediaServer without having to go through “factory defaults” and risk losing all this data, the data that is stored on this drive for backup purposes (i removed the content from several drives and have since recycled said drives)
Please WD, don’t tell me I have to “clear” all the data on this drive simply because I can’t access the media server. I bought this thing for a reason; tight budget + NAS need + media server replacement. My other option was a QNAP, and I regret having done so if this can’t be fixed by any other means than to copy over the entire 1tb+ of content over to another non-existant drive.
Thanks to anyone who can help, and in any way that I can provide any insight, I will take screenshots and pull out logs (from UI or SSH) so that we can get this media server up and running. A simple function of resetting the Twonky to factory defaults would be handy!
PEACE
