Hello, i bought a WD30EZRX 3TB and after a power cut the hd is gone from bios and makes a sound like in loop, can anyone help me? i attached an mp3 with the sound, the beep is from the computer start not the hd.
If possible, try using another SATA cable. You can also run a test using DLG. Check the link below for the steps.
